scanmaster compatibility
Old Feb 3, 2004 | 10:34 AM
30thannZ28's Avatar
I want to buy a scanmaster because I did most of the mods in my sig at the same time. I have a 97 Z, but it has a 95 Z ECU in it. Obviously, I still have the 97 size connector under the drivers side dash, so how would all this fair? I don't know much about the scanmaster, but I know I'll need it!
don't suppose anybody has a used one for sale.....
Old Feb 3, 2004 | 11:04 AM
Brent94Z's Avatar
Super Moderator
Will work just fine and you'll even be able to read the trouble codes.
You'll be in the same situation as I was (originally OBDII but converted to OBDI) so this guide should give you what you need for the wiring...
http://www.bfranker.badz28.com/fbody/scanmaster.htm
Check this out too... great info here...
http://members.aol.com/InjuneerZZ/ScanMast.htm
Old Feb 3, 2004 | 11:50 AM
OBE1 95Z28's Avatar
The Scanmaster doesn't plug into you ALDL port, it utilizes one of the lines. I just tapped into the line from behind the connector. Very useful tool to read PCM values real time.
Peytons'z
May 6, 2021 09:25 AM
marlar98
Sep 12, 2018 07:18 AM
marlar98
Sep 19, 2015 07:53 AM
BPS
Sep 12, 2002 01:42 PM
Geoff Chadwick
Aug 30, 2002 08:27 AM
