Gettint the Harmonic Balancer off of the freagin LT1
Old Jan 30, 2004 | 06:07 PM
SnortinLT1's Avatar
ive tried everything tot get it off ive even broken my torque wrench and a wratchet ive got a puller on it and i keep turning and turning it and it seam slike nothing is happeneing how od i get this off dangit thank you
greg
Old Jan 30, 2004 | 06:12 PM
Zepher's Avatar
Make sure that the puller is not bolted to the hub, if it is, then you are basically pulling against itself and it wont come off.
Blancer and hub are 2 seperate items.
Old Jan 30, 2004 | 06:35 PM
Sounds like you are trying to tear the hub apart. Are you aware it looks like this? If the center shaft of your puller is up against the inside of the hub, you are gonna go nowhere and break stuff. You need to put a hardened shaft into the crank bolt hole. It needs to be long enough so you puller will push against it until the hub is free.
Some people loosen the crank bolt and push against that, but I don't recommend that as you might destroy the threads.
Old Jan 30, 2004 | 06:56 PM
SnortinLT1's Avatar
ok so how far do the 3 bolts need to be screwed it yeah i ****ed up sio i leave the bolt in the hub screwed it??
Old Jan 30, 2004 | 07:08 PM
96ta(nick)'s Avatar
get a longer bolt so you can push against the head of the bolt, pr you can back out the stock bolt and push against it but i did that and had to rethread the bolt and crank. and it probably did not hurt it but try it the right way now...
Old Jan 30, 2004 | 07:29 PM
SnortinLT1's Avatar
ive got the wrong kindas of puller dont i? i need a gear puller or a jaw puller am i correct?? there arent any threads in the balancer just the hub??? **** that sucks
grge
Old Jan 30, 2004 | 07:43 PM
gb95zconv's Avatar
grge
I used a small 3 jaw puller.....it was still a biatch. I also sprayed it down with Rust Eater and and let it set an hour or so.
Old Jan 30, 2004 | 08:15 PM
polcat1p's Avatar
You can go to autozone and get the 3 jaw pulley basicly for free as long as you return it. I did the same thing as you at first.LOL
Chad
Old Feb 3, 2004 | 12:17 AM
ftransam1's Avatar
Just go to autozone and rent a harmonic balancer puller. You will have to go to a hardware store to get bolts to fit in the hub. Get 3" bolts and washers with nuts for the back. Take out the center hub bolt and go get a longer one or get something to go through the hole to push on. Make sure if you use the existing crank bolt you take off the washer and barely thread the bolt. then crank away on the puller. i had an airgun the second time I did it and it came off in a matter of seconds.
Old Feb 3, 2004 | 12:24 AM
95BlackTA's Avatar
Chad
my autozone is gay...they dont rent out tools for some reason!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Stupid college town!!!!!!!!!!!!!!!!!!!!!!!!!
Old Feb 3, 2004 | 11:51 AM
ftransam1's Avatar
well I would check somewhere else for one. Maybe you should just buy one. Harbor Freight sells 'em pretty cheap and I think autozone has them. also after you the hub off you might need to use a sledge to get it back on. Worked for me cause those hub installer tools don't have the right thread on 'em.
cyteone
Feb 7, 2015 06:04 PM
smokin5s
Jul 24, 2003 10:47 PM
1LEThumper
Jul 14, 2003 12:45 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
