scanmaster codes
Old Feb 28, 2004 | 11:33 AM
jeepz28's Avatar
scanmaster codes
I have a 95 m6 camaro. I just put my scanmaster in to see why my check engine light cameon and it is reading codes 36, 51, and 29. what are these and how hard are they to fix. and if anyone knows how mutch the parts would be
thinks
james
Old Feb 28, 2004 | 11:39 AM
Lyle A's Avatar
29- check the air pump fuse
36- distributor Ignition Faulty High resolution pulse or extra low resolution pulse. Could be the opti is failing or just a one time thing. Clear it and hope it doesn't come back. Check the wiring from the opti to the PCM. Shoebox's site has the diagrams and charts.
51- eeprom programming error. Might have something to do with the scanmaster but I'm not sure on that one. Could be a bad connection between the scanmaster and the DLC.
Old Feb 28, 2004 | 11:42 AM
jeepz28's Avatar
thinks for the info on the codes how do you reset the scanmaster to see if it comes back
Old Feb 28, 2004 | 11:53 AM
Lyle A's Avatar
I don't have a scanmaster so I can't tell you how to use it to reset codes but you can pull the PCM fuse for a few seconds to a few minutes and that will erase stored codes. I know the scanmaster will but I don't know the steps.
Old Feb 28, 2004 | 12:42 PM
You can not clear or reset DTC codes with a ScanMaster.
Pull the "PCM BAT" fuse (key in off position) for 30 seconds. On your 95 I think they put that fuse in the underhood box... but not sure.
Shoebox has the DTC codes on his tech pages. I have them at the end of my ScanMaster writeup.
Old Feb 28, 2004 | 05:08 PM
jeepz28's Avatar
thinks for all the info.
for the optispark is there a convirsion that makes it like a LS1 distributor to get rid of it.
what about the Delteq Opti-Direct Stage 2 any info on that.
thinks
Peytons'z
May 6, 2021 09:25 AM
Lt1son
May 27, 2015 10:35 AM
rick9696
Aug 7, 2002 03:28 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
