Scanmaster code 21??
Old May 27, 2006 | 09:26 PM
detroit1994z28's Avatar
My scanmaster is reading code 21 under the dtc mode. The car seems to be missing on high speeds. The code is for TPS sensor high. Does anyone know if I might need a new tps sensor?
Old May 27, 2006 | 11:39 PM
Re: Scanmaster code 21??
Turn the key on, set the ScanMaster to read the TPS voltage. What is the "throttle closed" voltage? Put your foot on the floot - what is the WOT voltage? When you slowly move the throttle from closed to wide open, does the voltage increase steadilly, with no spikes or flat spots?
Old May 28, 2006 | 09:25 AM
need to check that out - thanks - Mike
Peytons'z
May 6, 2021 09:25 AM
Lt1son
May 27, 2015 10:35 AM
rick9696
Aug 7, 2002 03:28 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
