Scanmaster
If im reading your question right...which I hope I am. yes the scan master will work for camaros as long as you get the one made for it. there are others that grand nationals use and its different but looks the same.
You need the "Scanmaster LT1". It will read the sensors and computer parameters in your 96, but will NOT read the trouble codes. The "LT1" version will only read trouble codes on 94/95 (OBD-I). And it will not work on the 1993 LT1 at all.
[edit] A quick check on the Ramchargers website indicates there is a LT1 version, LS1 version, L67 (GTP) version, and the original Buick Turbo version, which is the "Scanmaster 2".
88irocz28
Feb 28, 2003 11:24 PM
