safe to spin this high?
Old May 19, 2007 | 08:35 PM
TurboXL's Avatar
Want to get my car dyno'd again. I fixed my exhaust leaks and the engine was rebuilt about 750 miles ago so want to dyno it and see the difference from the last time. I was thinking about pulling it up to 6000rpms or so, but don't know if thats safe??
Also, what kinda gains should I see, if any, from the rebuild and fixing a header and y-pipe leak?
Old May 19, 2007 | 08:45 PM
Z28LT1_Just_Nasty's Avatar
Stock mail order tunes adjust redline 6000, so I can't imagine it harming anything.
Old May 19, 2007 | 08:50 PM
bombebomb's Avatar
You should be fine spinning to 6k for the dyno runs.
Old May 19, 2007 | 09:56 PM
wrd1972's Avatar
If you are running the stock cam then the power will be petering out at 6K RPM. You will not hurt the engine.
Seeing that you are making 350 RWTQ I cant see you having the stock cam.
Old May 19, 2007 | 11:03 PM
Dan Parker '96's Avatar
If you're running full roller rockers then 7K is hunky dory!
Old May 19, 2007 | 11:20 PM
TurboXL's Avatar
It is the stock cam... thats y I was worried mostly.
Old May 20, 2007 | 12:01 AM
ACE1252's Avatar
http://web.camaross.com/forums/showthread.php?t=519091
Old May 20, 2007 | 11:28 AM
TurboXL's Avatar
Sorry, don't know how I missed that one. Thanks Ace!
DirtyDaveW
Dec 1, 2016 05:37 PM
CGM2010CAMARO
Apr 7, 2015 07:44 PM
Jan 23, 2015 01:13 PM
simple
Aug 2, 2002 03:30 PM
