S.E.S light is on till open cycle
Old Oct 21, 2004 | 11:03 PM
NewbieWar's Avatar
S.E.S light is on till closed cycle
my light comes on as soon as u start the car and it runs ok, for a while then at about 165 Degrees or so it gets really ruff and the car feels likes its gonna stall then the light goes off and the car runs normally... what is wrong?
Old Oct 22, 2004 | 04:13 AM
slimdawson's Avatar
Re: S.E.S light is on till open cycle
The car is in open loop when you start it. It goes into closed loop. Maybe it is your o2s. They aren't used until closed loop although I don't know why it would get better.
Scan it and be sure before you start throwing parts that it might not need at it.
Old Oct 22, 2004 | 08:33 PM
NewbieWar's Avatar
sensors are brand new
Old Oct 22, 2004 | 11:51 PM
A scan, with a code would make it a whole lot easier. Do the fans run right from startup? Might indicate the AIR pump fuse is blown. But, we're just guessing at this point.
Old Oct 23, 2004 | 09:58 PM
NewbieWar's Avatar
well it started after i let it run for a few miles at 260degrees
Old Oct 23, 2004 | 10:30 PM
slimdawson's Avatar
I still don't have an idea. Get it scanned and you will more than likely find the problem.
Old Oct 23, 2004 | 11:03 PM
ShawnMacAnanny's Avatar
Sounds like your EGR. My little vacuun line came off it. Check and see, it right on the back fo the manifold. Didnt have a ruff idle, but it did set a code and idle would fluctuate.
Old Oct 24, 2004 | 02:53 PM
NewbieWar's Avatar
well now i just started it to move it to change my oil... got more than 5 qts out weird... usually much less... maybe jiffy lube gave me extra since my dipstic is broken off...
well i started it up and it stalled. then i ran the starter and the engine was going but didnt sound like it was sustaining itself... then it started and if i got on the gas it tried to stall until i got back off the gas...
i donno if this problem is relative...
Old Dec 11, 2004 | 01:16 AM
NewbieWar's Avatar
I got it scanned its the water pump temp sensor...
i just had it replaced not to long ago... 3 months maybe?
Old Dec 11, 2004 | 02:51 AM
Zack's Avatar
whered you get it scanned at? my t/a is being a POS with an SES light..not like i can drive it to where ever it was scanned anyways :-/
Old Dec 14, 2004 | 11:56 PM
NewbieWar's Avatar
it was a place in brea, the guy scanned it for me for free at dynomotions check em out at dynomotions.net i think. i was considering having him do my engine work... 383 lt4... but still working on finding a good shop maybe go someplace else, but i think i'll have him do my a4-m6 swap for sure and misc work.
DirtyDaveW
Dec 1, 2016 05:37 PM
Jlo
Feb 3, 2015 09:41 PM
David Dorris
Jan 17, 2015 08:10 PM
squarehead
Jan 15, 2015 07:02 PM
