Runs great then sputters
Old Jun 12, 2011 | 12:04 PM
jman1093's Avatar
Unhappy Runs great then sputters
So I have a 95 z28 and it will run fine for a while then sputters and occasionally backfires. After that it will run fine, but may sputter again. I think it's the opti since I've seen this before with this car (twice). Fixed the water pump so it wouldn't leak down onto the opti last time. Also no vacuum leaks. New TPS, starter, and new gaskets and seals because I had to fix an oil leak. If anyone can help let me know.
Old Jun 12, 2011 | 01:27 PM
Re: Runs great then sputters
Have you scanned if for codes? Have you checked the fuel pressure?
Under what condition does is "sputter" ( = misfire ?? ) - idle, part throttle, WOT, all of the above?
Trans type?
Any major mods?
Old Jun 12, 2011 | 05:29 PM
mrmint69's Avatar
I was thinking the fuel pump too. Any easy thing to check with the right tools. You would need to tape one to the windshield to be able to see if the pressure drops at higher rpm's.
Old Jun 12, 2011 | 07:06 PM
jman1093's Avatar
Fuel pump fine and filter fine. It sputters during acceleration sometimes. Most of the time it's when you're cruising at a constant speed, and then out of nowhere it sputters then keeps going. Have to take it to dealership to get codes read because someone put an OBD2 connector on an OBD1 system. Also the car is all stock.
Scottylt1
Jan 8, 2015 02:48 PM
Scottylt1
Dec 4, 2014 12:31 PM
nophix
Nov 30, 2014 10:26 PM
Lederman1976
Nov 30, 2014 05:21 AM
