runs faster with maf disconnected?
Re: runs faster with maf disconnected?
It sure does, it just runs without it. It uses other information to determine the fuel and air to use. I forget the term for running in this condition, either closed loop or open loop. I mix them up. Point is, it will run without it but it is better to have the MAF working.
Originally Posted by Pasky
If the PCM does not detect the MAF it will rely on speed density.
