Running Rich???
Old Apr 6, 2006 | 01:00 PM
Alpinetypers's Avatar
Running Rich???
I have Pace Setter LT's and 3" off road y-pipe that dumps into 3" exhaust piping and out of Quad Borla Tips. NO muffler and NO cats.
It seems to be running quite rich. Why would that be, and can I fix that?
Old Apr 6, 2006 | 05:18 PM
Re: Running Rich???
Leaks in the exhaust system before the O2 sensors can cause that problem.
Old Apr 6, 2006 | 08:11 PM
camzaro28's Avatar
Re: Running Rich???
Injuneer is right, i have the same problem as u. it is my my header flange not sealing right. anyway. do u hear any ticking from under the hood?
Old Apr 7, 2006 | 09:14 AM
Re: Running Rich???
sometimes.
will be checking for any leaks. thnx
Old Apr 7, 2006 | 10:33 AM
silentsprintero's Avatar
Re: Running Rich???
my friend told me somethin like this, not sure if its true or not. since theres increased air flow don't the O2 sensors read more air than fuel and tell the computer there isnt enough fuel (saying its running lean) so it sends more fuel to compensate for the increased amounts of air causing it to run rich?
-Chris
Old Apr 7, 2006 | 11:59 AM
Re: Running Rich???
Even if it would, you should still be able to override that with a good computer programming.......not???
Old Apr 7, 2006 | 01:19 PM
30th TA 0219's Avatar
Re: Running Rich???
yes, but you're on stock programming, no?
Old Apr 7, 2006 | 03:41 PM
Re: Running Rich???
Not.....
Leaks give you faulty excess air reading in the exhaust and produce exactly the result he outlined..... the PCM adds fuel you don't need.
The closed loop target A/F ratio is hard coded into the PCM. You can't change it. And it would be sort of pointless (or a$$-backwards) to try and change the programming to compensate for exhaust leaks, rather than correct the exhaust leaks. Using programming to cover up an engine's problems could hardly be categorized as "good programming".
DirtyDaveW
Dec 1, 2016 05:37 PM
Iamherefornow
Jan 26, 2015 04:57 PM
Donwest22
Parts Wanted
Dec 12, 2014 05:58 PM
Rich_z28
May 6, 2003 08:38 PM
Speeds8erM-1
Jul 18, 2002 11:36 PM
