running rich
Old Jul 20, 2005 | 11:33 AM
tranz350's Avatar
running rich
hey i installed a new air foil and ram air set up on my trans am with k n filter car has random tech high flow cat and borla. The car runs rich now and i dont now what to do. i gave it a new set of wires and bosch plugs still runs rich any ideas do i need the eprom programmed
Old Jul 20, 2005 | 11:48 AM
turbo_Z's Avatar
Re: running rich
Did you remove the exhaust manifolds or y-pipe? If you did then you may have created an exhuast leak.
what year is your car and why do you think its running rich?
Old Jul 20, 2005 | 12:45 PM
tranz350's Avatar
Re: running rich
didnt remove any maifolds just new air foil and ram air its a 95 m6 i might have to much air to fuel mixture with the added air it gets now
Old Jul 20, 2005 | 02:51 PM
slverbullet's Avatar
Re: running rich
Originally Posted by tranz350
The car run rich now and i not now what to do. i gave it a new set of wires and bosch plugs still runs rich any ideas do i need the eprom programmed
?? lol, might need to start proof reading before you hit the submit button.
an air foil and a ram air kit is not going to cause you to run rich.
Old Jul 20, 2005 | 03:06 PM
tranz350's Avatar
Re: running rich
car ran fine before they were installed then right after it started running rich thats why i am asking what it might be
Old Jul 20, 2005 | 03:45 PM
valter's Avatar
Re: running rich
Filter is clean? Maf connected?
Old Jul 20, 2005 | 09:21 PM
tranz350's Avatar
Re: running rich
yes i have cleaned the air filter and mass air flow is hooked up. do i have to much air intake to fuel ?
Old Jul 21, 2005 | 09:17 AM
Re: running rich
your computer regulates your air and fuel. not the kind of intake you have. i doubt seriously that the air foil is making any difference whatsoever. what is making you think that you are running rich? have you scanned the car and got some readings indicating that you are running rich or are you just taking a guess? if the answer is the latter, get some actual reading via your computer or a dyno to see what your a/f ratio is. or go and buy an a/f gauge.
Old Jul 21, 2005 | 09:19 AM
Re: running rich
i dont think you can run without a MAF sensor connected.
Old Jul 21, 2005 | 11:24 AM
valter's Avatar
Re: running rich
Mine is running without MAF, poor though. Another thought - I know it sound stupid, but check whether MAF is put backwards.
Old Jul 21, 2005 | 11:27 AM
ZMAN Z28's Avatar
Re: running rich
Yes you can run your car without the maf. It will not go into closed loop. Provided you have a non 93.
Z
DirtyDaveW
Dec 1, 2016 05:37 PM
Iamherefornow
Jan 26, 2015 04:57 PM
Donwest22
Parts Wanted
Dec 12, 2014 05:58 PM
Rich_z28
May 6, 2003 08:38 PM
Speeds8erM-1
Jul 18, 2002 11:36 PM
