Running bad at start up
Old Sep 28, 2005 | 11:49 AM
Honda Hunter's Avatar
After changing the coil, wires, plugs, opti, replaced map sensor, replaced the header gaskets, and fuel pressure regulator the car seems to miss. We disconnected the batt for a while then tried it again but it didnt work. One odd thing we noticed was when we disconnected the MAF sensor it ran better. We decided tommrow we will replace both o2 sensors and the maf in hopes of figuring this out. I'm sure the opti and wires are in right, what else could the issue be? Should we have let it warm up and go into closed loop? Any ideas?
Old Sep 28, 2005 | 02:35 PM
faded93bird's Avatar
Re: Running bad at start up
assuming the car is tuned
I would check the injector connectors, and their wireing.
Check for vacumme leaks, and double check those spark plug wires.
97z28k&N
Jan 9, 2015 04:58 AM
dirtybird81
10
Jan 6, 2015 09:31 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
Noenav
Dec 6, 2014 07:35 PM
