Run fuel pump with engine off?
Old Sep 15, 2008 | 12:55 AM
94FBIRD's Avatar
How can I run the fuel pump with the engine off? I need to drain the tank to fill it with race gas. Thanks in advance.
Old Sep 15, 2008 | 01:35 AM
mrmint69's Avatar
Never heard of anyone trying it. If you disconnected the fuel line at the fuel filter and could keep the pump running by a power source it just might work. I would just get on the interstate and run it low that way. I heard of people dropping the tank to remove old gas because it sat for too long. Maybe you could siphon it but on my other car the rollover ball prevented me from doing it.
Old Sep 15, 2008 | 05:26 AM
There is a fuel pump prime connector near the PCM. You supply +12V to that connector, and the pump will run. Shoebox has a photo:
http://shbox.com/1/fuel_pump_prime.jpg
It will also siphon... I do that regularly when running C16.
Old Sep 16, 2008 | 02:05 AM
94FBIRD's Avatar
Thanks Fred! That is exactly what I needed!
BADAZZ_Z
Parts Wanted
Mar 5, 2019 12:55 AM
FIREBIRDMARK1
Jan 7, 2015 03:36 PM
Jessie4tin
Jan 7, 2015 08:53 AM
ANDYZ28
Dec 29, 2014 09:13 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
