RR questions
Old Jul 7, 2007 | 12:01 AM
reamo04's Avatar
RR questions
looking at RRs for my motor, they will go in my current motor til the 383 is finished, then go in that. The 383 will have TFS heads and a LPE 219/219 560/560 cam. My question:
Will 3/8 rockers be fine? Trying to keep price to a minimum here
Will comp pro-magnums be my best bet, or what other alternatives do i have?
Old Jul 7, 2007 | 04:20 AM
Joe B's Avatar
If you need to buy rockers then there's really NO reason at all not to go with the 7/16 rockers(same cost).........IMO, Your best bet is the NSA 7/16 Pro-Magnums and a set of ARP 7/16 studs for 25 bucks......going 7/16 creates a MUCH more stiff valvetrain, and they NEVER break.....where as 3/8 studs break commonly......I would think that since your going thru the expense of aftermarket heads and a 383....adding guideplates and a set of hardened pushrods (for NSA rockers) should be part of the plan anyway.........Joe
Old Jul 7, 2007 | 06:24 AM
rskrause's Avatar
Moderator
The cross section of a 7/16" stud is ~36% larger than that of a 3/8" and the strength is going to be proportional to the x-section. So, definitely get a set of good 7/16" rockers studs if you are upgrading your valvetrain.
Rich
Old Jul 7, 2007 | 08:56 PM
reamo04's Avatar
alright guys, thanks. Are the studs i need the ones from thunderracing.com im assuming? I looked on summit and they have a bunch of different sizes, where thunderracing just lists them under LT1.
Some reason i thought the studs were more $$ than that. Thanks for the input guys.
Old Jul 7, 2007 | 09:08 PM
user 647483's Avatar
7/16 NSA Pro Mags .. absolutely!
I used th 7/16" ARP studs from Thunderracing.
Old Jul 8, 2007 | 12:47 AM
reamo04's Avatar
for NSA, i need guide plates, correct? Where do i get those from, and what are the best ones to get, etc.
Old Jul 8, 2007 | 05:30 AM
Joe B's Avatar
Many of us use the GM LT1 guideplates(about $25 from summit)......but several guys here have had issues with a couple here and there not being hardened enough, and excessive wear was the end result........some have now gone to the trickflow guideplates, and the Isky "adjustables" are good as well, but "I believe" they have to be spot welded after they are adjusted correctly....... I just recently ordered a set of manely guideplates that are supposed to be good(but I can't recomend them since I havent tried them yet)......Here's some more info....http://web.camaross.com/forums/showt...t1+guideplates also don't forget to go with a good set of hardened pushrods like the Comp Cams "Hi-Tech" ones........don't skimp on pushrods
Old Jul 8, 2007 | 01:08 PM
reamo04's Avatar
Thanks man. Would there be any advantage w/ the comp "hi tech" pushrods over the 94 hardened pushrods assuming the length didnt change?
Old Aug 3, 2007 | 02:48 AM
Joe B's Avatar
Sorry for the slow responce.........Yea, the Comp "Hi-Tech"(80thou wall thickness) pushrods are litterally "world's" better(reguardless of length).....They're a MUCH MUCH stronger pushrod made from a better material...and they also have a "real" hardening process, and were designed to give off less harmonic's as well........Joe
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
