RPM Idle Down Issue
Old Jul 25, 2003 | 06:14 AM
GRN96WS6's Avatar
RPM Idle Down Issue
When driving my car to/from work sometimes when depressing the clutch pedal the RPM's will stay at 2K instead of coming down like it should. It does not do this everytime but I want to attemtp to fix it as it shouldnt do this. I can get it to idle down by blipping the throttle, but there has to be something dirty or causing it not to idle down on it's own.
Old Jul 25, 2003 | 06:19 AM
mc63's Avatar
Yes, you need to replace the throttle linkage cable.
Old Jul 25, 2003 | 07:02 AM
GRN96WS6's Avatar
Does that cable go all the way to the gas pedal? That doesn't sound cheap. I would think if the cable is bad wouldn't it do it everytime?
Old Jul 25, 2003 | 08:01 AM
mc63's Avatar
Sounds to me like it's going out.
Some things break all at once, others go out slowly.
Old Jul 25, 2003 | 08:11 AM
To check the cable, have someone operated it (with engine off), while you watch it at the throttle body to see if the linkage is closing all the way. I would have my doubts that it is a cable problem. Sounds more like an IAC issue. It and it's passages on the throttle body may need to be cleaned.
Old Jul 25, 2003 | 08:34 AM
GRN96WS6's Avatar
That's what I was thinking the IAC, I have heard mention of this before. I will look at it this weekend I suppose.
Cam's maro
Mar 24, 2015 08:09 PM
lt1matt
Mar 21, 2015 07:35 PM
edman
Mar 13, 2015 09:39 PM
1996LT1Z28
Mar 8, 2015 08:16 PM
David Dorris
Jan 17, 2015 08:10 PM
