Rounded off the drain plug, what else can I do?
Old May 20, 2008 | 08:58 PM
  #16
94zgreenmachine's Avatar
Maybe I missed it, but have you tried the universal metric wrench(vise grip)
Old May 20, 2008 | 08:59 PM
  #17
ShownomercyZ28's Avatar
I wouldn't think it would fit in there. Worth a try though
Old May 20, 2008 | 11:42 PM
  #18
We are talking about the drain plug on the bottom of the block, just above the oilpan. It is opposite of the knock sensor, correct?
Old May 20, 2008 | 11:54 PM
  #19
Jazsun's Avatar
Ya its completely round now, no wrench is gona help. I'll just bite the bullet and let the coolant flow. Will it hurt anything to have some fall in the cylinders?
Old May 21, 2008 | 10:35 AM
  #20
I suppose you wouldn't have access to a TIG welder. If you could, weld a piece of flat stock to the rounded plug. The heat from the weld alone could be enough to help break it free. The flatbar could also act as a torque multiplier(handle)....
Old May 21, 2008 | 11:02 AM
  #21
Jazsun's Avatar
I'll have to take it to a shop and have them do that sometime. Right now I just need to get my heads off.
Old May 21, 2008 | 11:04 AM
  #22
Jazsun's Avatar
I think I am going to pull the lower driverside w/p bolt, hopefully does the trick. I got the knock sensor out on the otherside.
Magenta_Hearts
Mar 29, 2017 08:54 PM
gillta95
May 8, 2015 07:46 PM
eanhl2004
Apr 4, 2015 12:01 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
Sandersen511
Jan 13, 2015 03:49 PM
