Roller rockers not going on right
Old Aug 15, 2003 | 02:15 PM
  #16
drewstealth's Avatar
Yeah i'm pretty sure he did also. So does that mean that the self-aligning are better? Also if they are why wouldn't everybody just get those since there isn't that much of a price difference. Is there any thing better about the non-aligning?
Old Aug 15, 2003 | 07:28 PM
  #17
12SCNDZ's Avatar
Hmm..Let's all take engine advice from a guy running 13's... I also noticed you have your location listed as "Under your car"??? Maybe when you get it right, you can spend some time driving it.
Frank
>QUOTE]Originally posted by NOMAD
[B]
Custom cam and the page hasn't been updated for over a year now smarty pants. The first combination didn't like the broken crank. I've been running this setup for almost 10,000 miles so far, but I do keep a check on the valve train (Which should be done since it is Non SA). No alignment problems whatsoever, sorry. When an engine is built by a competent engine builder and not some fly by night engine shop, I don't worry about 6800 on an all stock rebuild bottom end. Then again, maybe we just know how to build engines around here. BTW, I have the "right" guide plates thank you
Seems like your so sure after posting this only a month and a half ago.
-Shannon
BTW, I don't get into pissing matches. I know what works, believe what you want.
[/QUOTE]
Old Aug 15, 2003 | 07:47 PM
  #18
gb95zconv's Avatar
Originally posted by 12SCNDZ
. COMP plates won't work, as they're made for standard SBC...Which have the valves .050" closer than an LT1.
Dont know for sure but I read somewhere that center to center they are the same which means the standard SBC guideplates should work.
13qtr
Oct 28, 2016 08:11 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
