Roller Rockers - New Valve Covers?
Im installing 1.6 Comp Pro Magnum 7/16 non self aligning roller rockers with GM guide plates. Do i need any modification to my stock valve covers? Or do i need completely new valve covers? If so where can i get them?
With some modification, I understand it is not necessary to replace the oem valve covers. BUT golly, what a great reason to now move up to a nice set of aftermarket alum covers and get rid of those ugly oem jobs.
There is a support bracket on each hold down bolt tube. They are wide enough that they won't fit between the rockers so you have to trim the support between the rockers. The support has a 90 degree bend along the edge that you grind off.
All you have to do is bend the little lip of the brace that is running parallel to the top of the valve cover. One on each side of the bolt tubes.
I heard that if you cut to much of the bracing out it could cause the vavle covers to leak after they are tightened down.
oldschool
Feb 9, 2016 09:21 PM
JasonD
Jul 27, 2002 08:57 PM
