Roller Rockers and .600+ Lift?
Old May 30, 2003 | 12:26 PM
R_Andersen's Avatar
I'm trying to determine what roller rockers to go with. I will be running a 230/236 cam with .598"/.608" lift. I had found a good deal on the GM Perfomance parts Aluminum roller rockers, but I saw on one site that they are only good up to .575" lift. (I believe these are the same as the either crane or comp cams rockers but I forget which ones).
I'm wondering what roller rockers are capable of supporting lifts of over .600"? Also, what limits a roller rockers lift capability? Any help would be appreciated.
Thanks,
Rob
Old May 30, 2003 | 12:52 PM
atljar's Avatar
im running .575/.595 lift with comp pro mag 1.6 without any issues. They are about 235 for the non SA.
Old May 30, 2003 | 01:36 PM
R_Andersen's Avatar
It appears these rockers are identcal to the Crane Gold roller rockers. I was wondering if anyone is using the Crane version with high lift cams as I do not see any restrictions on lift noted on Crane's web site.
Thanks,
Rob
Old May 30, 2003 | 01:43 PM
rskrause's Avatar
Moderator
Thanks,
Rob
With a high lift cam you should always be careful to check the clearance of the rocker body and the valve retainer, but rating a rocker for a certain lift is something I never heard of.
I am using the Crane's and my exhaust has .587" lift with no clearance problems, if that's of any help.
Rich Krause
Old May 30, 2003 | 01:58 PM
4drLT4's Avatar
exhaust lift of .640 w/Pro-Magnums. No problems whatsoever.
Old May 30, 2003 | 02:06 PM
EvlViln's Avatar
Yeah Bob, but lets not talk about Valve Lash!
Nutty's96
Dec 21, 2015 06:25 AM
sleeperZ96BT
Sep 9, 2015 08:28 AM
Slayer
Aug 17, 2015 03:55 PM
Mir Hussain
Outside of United States
Aug 8, 2015 07:00 PM
9t4lt4z28
Parts Wanted
Jul 19, 2015 06:16 PM
