Roller Rockers and .600+ Lift?
I'm trying to determine what roller rockers to go with. I will be running a 230/236 cam with .598"/.608" lift. I had found a good deal on the GM Perfomance parts Aluminum roller rockers, but I saw on one site that they are only good up to .575" lift. (I believe these are the same as the either crane or comp cams rockers but I forget which ones).
I'm wondering what roller rockers are capable of supporting lifts of over .600"? Also, what limits a roller rockers lift capability? Any help would be appreciated.
Thanks,
Rob
Thanks,
Rob
It appears these rockers are identcal to the Crane Gold roller rockers. I was wondering if anyone is using the Crane version with high lift cams as I do not see any restrictions on lift noted on Crane's web site.
Thanks,
Rob
Thanks,
Rob
Thanks,
Rob
Thanks,
Rob
I am using the Crane's and my exhaust has .587" lift with no clearance problems, if that's of any help.
Rich Krause
sleeperZ96BT
Sep 9, 2015 08:28 AM
