roller rocker questions (tune, springs)
Old Aug 13, 2007 | 06:49 PM
  #16
Stl94LT1's Avatar
Originally Posted by BUBBA
Go with either the 99892 or the new design 99893 which is supposed to last longer. It is a dual coil spring. It will fit without machining.
A 1.460 OD spring will fit the stock seats?
Old Aug 13, 2007 | 07:37 PM
  #17
MeanGreen97Z's Avatar
Do you really want to use springs that have been on the car for a while when you upgrade the cam? Do the LT4s and 1.6 RRs for now. Replace the springs with new ones when you do that cam! Dont half *** it and cut corners.
Old Aug 14, 2007 | 07:12 AM
  #18
Yeahdoug's Avatar
Originally Posted by reamo04
crane 99892's i believe, but i cant find out if their dual or single spring,
http://cranecams.com/?show=browsePar...tType=camshaft
theres a link for the cam card
it calls for a spring thats
Closed 130 LBS @ 1.850 or 1 27/32
Open 314 LBS @ 1.360
Can you guys get that much install height on your stock heads. I know sometimes the LS1 guys can barely get 1.800".
PAC-1218 would be a good drop in spring for you.
oldschool
Feb 9, 2016 09:21 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
