roller rocker questions (tune, springs)
Old Aug 11, 2007 | 05:31 PM
reamo04's Avatar
alright, picking up some comp pro-magnum RRs (1.6), right now i will run strictly bolt on only, but i was wondering, what will the effect on my tune be? make it run leaner?
also, for springs, should I just pick up LT4 springs then? or would LS1 springs work
Old Aug 11, 2007 | 05:40 PM
Stl94LT1's Avatar
The rockers will have very little effect on your tune, and just to be safe you should change the springs. Whet spring to go with depends on future mods.
Old Aug 11, 2007 | 06:08 PM
reamo04's Avatar
well, for my next motor, i am getting heads from AI with a custom grind cam, so i would probably need to change springs then anyways, otherwise i am really looking the crane 227 or LPE 219/219 560/560 cam where id be fine getting springs now.
Also, does anybody know how much power im looking at gaining here?
Old Aug 11, 2007 | 06:14 PM
Stl94LT1's Avatar
If you plan on upgrading the heads, for now I would go with the LT4 springs. They are cheap (~$30), and will work fairly well with the 1.6 rockers.
You'll gain 10-15 hp by upgrading to the 1.6 RR's.
Old Aug 11, 2007 | 06:19 PM
wrd1972's Avatar
No effect on tune.
Old Aug 11, 2007 | 09:01 PM
reamo04's Avatar
does anybody know what springs for the crane 227 or LPE 219/219 560/560?
i will just get springs for one of those since i plan on running one anyways lol, and this way it will push meinto getting it done sooner
Old Aug 12, 2007 | 11:10 PM
reamo04's Avatar
ok, im gonna go ahead and buy the springs for my cam swap, will it hurt anything by going with the bigger springs for the 227?
Old Aug 12, 2007 | 11:21 PM
Stl94LT1's Avatar
Which bigger springs are you talking about?
Old Aug 12, 2007 | 11:41 PM
reamo04's Avatar
crane 99892's i believe, but i cant find out if their dual or single spring,
http://cranecams.com/?show=browsePar...tType=camshaft
theres a link for the cam card
it calls for a spring thats
Closed 130 LBS @ 1.850 or 1 27/32
Open 314 LBS @ 1.360
Old Aug 13, 2007 | 12:41 PM
Stl94LT1's Avatar
My uderstanding is the 99892's are a version of the 99893's. The 99893's are good to .710 lift and are a dual spring. Are you sure you need this much spring in your car? You'll also have to pull the heads to have the valve seats cut to fit the dual springs.
Old Aug 13, 2007 | 01:34 PM
WestCoast96Z28's Avatar
Even though no affect on tune, you should get your car re-tuned anyways to get the most out of the rockers. I used LT4 springs with my 1.6RRs.
Old Aug 13, 2007 | 01:50 PM
reamo04's Avatar
im trying to find a single-spring that will work for the 227, i guess i'll just call up crane
Old Aug 13, 2007 | 02:43 PM
Stl94LT1's Avatar
What is the lift of the 227?
Crane makes an H11 Tool Steel single spring that is good to .600 lift. Then you have the Comp/PAC 918 that is good to .600. PAC also makes a special 918 that is good to .650.
Old Aug 13, 2007 | 03:17 PM
reamo04's Avatar
479/518, so maybe even a LT4 spring would work? im not entirely sure.
Im not even sure if it matters, because my custom lunati came for my 383 today haha, and that will have to get those pacs that are good to .650, maybe even a bigger spring lol
Old Aug 13, 2007 | 04:23 PM
BUBBA's Avatar
Go with either the 99892 or the new design 99893 which is supposed to last longer. It is a dual coil spring. It will fit without machining.
I use the 99892 on my 227---max lift is 640. The 227 max lift is 552. JMHO
