Rocker Arm Wear
Old Dec 19, 2007 | 03:51 PM
jchevy's Avatar
Rocker Arm Wear
Ive been hunting down a tick in my motor and noticed this wear on my roller tip. You can see it in this pic on the side of the arm right by the roller. Is that normal? Ive noticed all the rockers have this.
These are self aligning right?
Old Dec 19, 2007 | 10:32 PM
SS RRR's Avatar
looks like the valve tip is smacking the rocker. could be because the rocker was adjusted too loose.
Old Dec 19, 2007 | 11:13 PM
camarozz95's Avatar
are you sure those are self-aligning? mine are self-aligning and they look a bit different than that. Maybe I'm wrong though
Old Dec 19, 2007 | 11:22 PM
Stoopalini's Avatar
Those are self aligning.
Did you replace the springs when you installed the rockers? Looks like the retainer might be making contact with the rocker. Some use offset locks to compensate for this type of thing, but you have to be careful with install heights.
Thomas.
Old Dec 19, 2007 | 11:31 PM
jchevy's Avatar
I think its rubbing the valves stem tip. The locks are retainers are below where the rocker can touch them. ALL my rockers show a little wear, but this one was the worse. This particular one was also noisier than the rest.
Old Dec 20, 2007 | 12:08 AM
brubaker's Avatar
Those are self allighning hope your not running guide plates!!!
Old Dec 20, 2007 | 02:16 AM
SS RRR's Avatar
Is there no pushrod cup in that rocker? Did you get these rockers used or new?
Old Dec 20, 2007 | 10:12 AM
jchevy's Avatar
I got them new, the cup is at the bottom in the picture by where the 1.6 is stamped... right?
They are comp pro mags if I remeber correctly, its been a while.
Old Dec 20, 2007 | 11:00 AM
Stl94LT1's Avatar
Yes, they are Comp's Pro Magnums and the pushrod cup is correct. The cups are part of the rocker body, not an add on.
Old Dec 20, 2007 | 02:13 PM
brubaker's Avatar
That damage is from the valve tip! do you have guide plates? if so get rid of them or run non self allighning. dont use the two togather.
Old Dec 20, 2007 | 02:15 PM
jchevy's Avatar
No, im not using guide plates
2QUIK6
Sep 17, 2016 02:31 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
realistyc
Jul 28, 2015 07:32 PM
94Form
Jul 17, 2015 10:56 PM
Jul 17, 2015 02:47 PM
