Rocker Arm Stud and Guideplate Installation??
Old Jan 24, 2004 | 11:15 PM
Brandon 95 Z28's Avatar
Hey,
I just installed my gm guideplates and ARP rocker arm studs. I used arp thread sealant on the studs and torqued them down to 50 ft lbs, with the guideplates underneath with the open square shaped side for the pushrod to pass through, does this sound right??
Thanks,
Brandon
Old Jan 25, 2004 | 02:23 AM
ttt, putting the heads on in the morning!
Old Jan 25, 2004 | 08:10 AM
There is some stampings on the GM guideplates (maybe "05" and "P") that is the top side. They should be clamped down by the studs. The only thing I would have done differently is use threadlocker and not sealer.
Old Jan 25, 2004 | 08:23 AM
12SCNDZ's Avatar
You shouldn't tighten your studs until you get your plates aligned correctly. This is a little time consuming, but you want to make sure all your rockers are centered on the valve tips. Even the GM plates have a little lateral movement.
Frank
1775.Z28
Jan 11, 2015 10:51 AM
Catmaigne
Dec 25, 2014 12:16 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
Brandon Wittmer
Dec 7, 2014 12:15 PM
newby
Jul 25, 2002 03:22 PM
