NEW MOTOR squeaking from under valve cover HELP!!!
Old Jan 23, 2004 | 04:08 PM
97ramairtransam's Avatar
i have a brand new motor i just got done putting together and getting running today in my 95 ta well when the car is started cold it doesnt make the noise, but after it gets hot at idel it starts making a loud squeaking noise sounds like its under the valve cover!!! like maby a spring i had the heads reworked and had ex componets 612s springs installed!! i also have 1.6 rr if anyone can tall me what im hearing and how to fix it ! it would be great!!! car runs great other than this noise and it is pretty loud!!
Old Jan 24, 2004 | 04:19 AM
aintno6's Avatar
Im not the best person to give you the anwser to this, but I would pop that valve cover. My guess is that your probably runing roller rockers right? If so, are you runing stock valve covers? Im wondering if its making contact under there? But pull the cover off. When I took mine off no oil leaked.
I just hope its the drivers side, cause the passanger side is a PITA!
Old Jan 24, 2004 | 05:13 AM
Don 97 SS's Avatar
Get a $10 stethescope from an auto parts shop and try to track down the location of the squeak. Are you sure it is under the valve cover or on the bottom end? Do you have good oil pressure?
Old Jan 24, 2004 | 09:51 AM
riceinmybowl's Avatar
this is just a seggestion, it happened to me. when you rebuilt it, did you put on guideplates? yoou see when i did my 1.6rr last week, my dumb azz put the rockers on top of the studds rather than below the studs and my rr rubbed bad! luckly i caught what i was doing before i finished the pass side and fixed them. maybe that is you sound. i got some funny sounds adjusting mine! if this is the problem, do like me, put the guides in right, and get an oil chang!
Old Jan 25, 2004 | 08:22 AM
Don 97 SS's Avatar
AS mentioned above there could be a number of items not installed just right or in need of adjust on a fresh engine. Get in there and take a look.
Hey, riceinmybowl, I used to live in Martin. My wife taught pt-time at UTM in the english dept. and I was the CEO of Volunteer General Hospital. I miss that place.
Old Jan 25, 2004 | 09:10 AM
bummer, it is a nice place. i cant seem to find a cz28 person here, but i did find one WTFA member.
LeftoverChinese
Jan 14, 2024 03:03 PM
HectorM52
Jul 30, 2017 11:46 AM
Jazsun
Dec 29, 2014 12:14 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
