rings or starter?
Old Apr 23, 2007 | 10:15 PM
95z28_m6's Avatar
rings or starter?
How tight can the piston rings be before they are broken in? The starter would bog down and not turn the motor over fast enough. I pulled the motor and checked the bearing clearinces.(all within spec) The only thing I found was that I switched two of the rod caps. I fixed it and put it back together, but it still seems hard to turn over. (motor is still on the stand) Is it possiable that the rings are just tight because they aren not broken in yet, or could the starter just not be able to handle the added compression. Just installed le2 heads and cam. Just gettin frustrated. havent driven the car in a year and a half. Also I did check the rings by putting them into the bore, but I didnt use a feeler gauge to see the exact clearance. They were a pita to instal though.
Old Apr 24, 2007 | 04:34 AM
SS RRR's Avatar
What were you using to power the starter?
Old Apr 24, 2007 | 08:29 PM
95z28_m6's Avatar
well I put it back into the car so I used the regular starter
Formula Steve
Sep 19, 2023 08:31 AM
magman
Apr 15, 2016 03:08 AM
IndyZman
Oct 22, 2015 02:17 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
mmf_1013
Sep 12, 2015 08:56 PM
