SCE Copper Head Gaskets
I was just mocking up my engine, when i placed the new SCE head gaskets in place, I noticed that some of the holes in the block don't line up perfectly with the holes in the head gasket....Will this cause cooling problems or any oil problems? Did anyone else run into this before?
Sorry, I can't directly answer your question. But I am curious about your choice of a copper head gasket. Is this a race car? Every copper gasket I have ever seen seeped coolant and was not suitable for a street car. Also, they are not needed except where cylinder pressure are VERY high (high boost, huge nitrous) or when a very thick gasket is needed to lower CR or to increase piston to valve clearance. If you have those Titan ACS, maybe they won't leak - they have a rubberized coating which is supposed to prevent leaks. If you have a regular copper gasket, fudgedaboutit.
Rich
Rich
It isn't really a street car, but i sometimes drive it on the street, i bought them looking for something that would support high boost....any other suggestions on a good head gasket for high boost that wont leak? Thanks
The Cometic would be a better choice, but as with copper the heads and block deck need to be flat, smooth, and straight to avoid leaks. I have run my LT1 with 26psi and the Fel Pro #1074 with no issues. How much boost are you planning on?
Rich
Rich
Even the Titan ICS will weep a little bit in my experience, even with some hylomar or copper coat sprayed on the gasket - I see just a slight bit of wetness at a couple spots sometimes, but they hold insane cylinder pressure. For a street car even with moderate boost pressure the fel-pro's and studs will hold just fine like Rich said.
