The Right oil pump.
Old May 9, 2009 | 07:16 PM
daniel1988's Avatar
The Right oil pump.
I'm trying to find the right oil pump to put in my LT1, I have a stock motor with a stock pan. Assuming it had standard clearances i'm looking at the Melling 10554, But I see everyone using these with high pressure springs?
Is the stock pump a high pressure/standard volume pump or what?
I wouldn't think it needed to be high volume or pressure if the clearances are right, but I can't find the right answer.
Old May 9, 2009 | 10:34 PM
rskrause's Avatar
Moderator
A stock pump is fine in a stock motor.
Rich
Old May 9, 2009 | 10:39 PM
The 10554 with a white spring is a good choice. A stock pump is standard volume. The additional pressure from the white spring is a little insurance.
Old Jul 5, 2009 | 10:52 PM
green96ta's Avatar
huh
not trying to high jack a thread but will this help prevent the classic rod bearing problems the lt1 is known for?
Old Jul 5, 2009 | 11:20 PM
96capricemgr's Avatar
These things are 12+years old. You know how many stretch cycles there are on the rods/bolts?
That said you now how many cycles the oil pump pressure spring has on it? IMO a higher pressure spring in a stock pump is a good thing BUT more because it is replacing a weak old one than because it is high pressure.
HectorM52
Jul 30, 2017 11:46 AM
FredM
Jun 5, 2015 05:45 AM
KYWes
Apr 15, 2015 07:11 PM
Sandersen511
Jan 13, 2015 03:49 PM
Queens94z28
Dec 20, 2014 09:11 PM
