Resetting the PCM?
Old Nov 22, 2003 | 07:03 PM
wm_sorg's Avatar
Question Resetting the PCM?
I had an issue related to a bad battery. After I replaced it the car started, however it was running VERY rich and threw a code. This was the first time it ever did this. I am guessing it had something to do with the PCM being upset when connecting the new battery.
The problem has not reappeared since.
Is there any to reset the PCM gracefully without disconecting the battery? Does it have it's own fuse. If so where is it located?
Regards,
BILL
Old Nov 22, 2003 | 07:06 PM
gb95zconv's Avatar
Yes it has its own fuse....remove it for 10 min or so and you should be reset.
Old Nov 22, 2003 | 08:32 PM
wm_sorg's Avatar
Thank you!
Old Nov 22, 2003 | 08:38 PM
Depends on what year your car is as to where the fuse is located. Look for PCM BATT. On a 1995, it should be under the hood and may say just PCM. Most other years, it is in the fuse panel on the left of the dashboard. 10-15 seconds is all it takes to reset the pcm.
Nayr
Mar 3, 2023 08:34 PM
93 RedBird
Nov 15, 2015 08:24 AM
fift5
11
Oct 1, 2015 10:31 AM
drt
Sep 27, 2015 04:39 PM
MDZ28
11
Sep 24, 2015 09:15 AM
