Reseting the PCM?
Old Feb 1, 2003 | 08:46 PM
LethalTA's Avatar
Reseting the PCM?
What is the proper procedure for reseting your PCM? Is it just unhooking your battery after every bolt on or is there a certain procedure involving pulling fuses?
should this be done after every bolt on if you dont have computer tuning?
Old Feb 1, 2003 | 08:49 PM
Rodrigues's Avatar
I think you just unplug the battery... What kind of bolt ons are we talking about?
teke184's Avatar
doesn't need to be done after every bolt on. but it is advisable to discoonnect the battery prior to doing any electrical mods. this prevents any shorts or voltage spikes.
if all you want to do is clear the ecm just pull the fuse in the panel in the door jamb area. it is on the bottom row, i think 3rd from the left...but the diagram on the cover lists witch one...
Old Feb 1, 2003 | 08:52 PM
n2ceptor's Avatar
The fuse panel on the side you will see a fuse marked PCM or ECM BATT ..... remove it....wait about 20-30 seconds and replace.. Its that easy...
93Z Wil
Nayr
Mar 3, 2023 08:34 PM
93 RedBird
Nov 15, 2015 08:24 AM
fift5
11
Oct 1, 2015 10:31 AM
drt
Sep 27, 2015 04:39 PM
MDZ28
11
Sep 24, 2015 09:15 AM
