Replacing opti in a Corvette?
Does anyone have link to a step by step procedure for doing this? It looks to me like its a lot harder to do in the Corvette than the Camaro because of the frame running across the front of the motor and the power steering rack. It looks like you have to tilt the motor to get a puller on the balancer to me, but if there;s an easier way, I'd much rather go that route. Thanks in advance. Also the car is a '94 if that matters.
If you search on corvetteforum you can find plenty of threads on the subject, many with pictures. Probably can find info on other corvette forums as well.
The balancer does have to come off. The balancer is the pulley.
It may just come off, but if it doesn't, you can get a puller on it. I used a small 2-jaw puller on it, running the screw of the puller under the loop on the p/s hardline.
grabbem88
Mar 18, 2015 01:25 PM
Alex Barnes
Jan 24, 2015 10:21 PM
bonniew
Events and Cruise Spots
Jan 18, 2015 01:14 PM
