Replacing opti in a Corvette?
Old Jun 15, 2007 | 12:57 PM
Stroked&Poked's Avatar
Does anyone have link to a step by step procedure for doing this? It looks to me like its a lot harder to do in the Corvette than the Camaro because of the frame running across the front of the motor and the power steering rack. It looks like you have to tilt the motor to get a puller on the balancer to me, but if there;s an easier way, I'd much rather go that route. Thanks in advance. Also the car is a '94 if that matters.
Old Jun 15, 2007 | 01:06 PM
CrazyLT1's Avatar
You do not need to pull the balancer off
Just take off the 3 bolts that hold the pulley on and take only the pulley off
The opti will slide off past the pulley
Old Jun 15, 2007 | 01:42 PM
sbs's Avatar
sbs
It may just come off, but if it doesn't, you can get a puller on it. I used a small 2-jaw puller on it, running the screw of the puller under the loop on the p/s hardline.
If you search on corvetteforum you can find plenty of threads on the subject, many with pictures. Probably can find info on other corvette forums as well.
Old Jun 15, 2007 | 01:44 PM
sbs's Avatar
sbs
Your terminology is very confused. Pull the pulley off but slide the opti off past the pulley?
The balancer does have to come off. The balancer is the pulley.
Old Jun 15, 2007 | 02:02 PM
CrazyLT1's Avatar
sorry- i was thinking you meant take the balancer hub off
Old Jun 15, 2007 | 03:20 PM
Yep, probably better to get good info from a Corvette forum, rather than from an f-body forum.
grabbem88
Mar 18, 2015 01:25 PM
grabbem88
Parts Wanted
Mar 8, 2015 04:08 PM
nikolt1
Feb 27, 2015 09:10 PM
Alex Barnes
Jan 24, 2015 10:21 PM
bonniew
Events and Cruise Spots
Jan 18, 2015 01:14 PM
