Replace slightly used lifters in new engine after a spun bearing?
Old Jan 24, 2004 | 04:25 AM
v7guy's Avatar
just replaced the lifters in my motor about 2000 miles ago, spun a bearing and found metal in the oil, do I have to replace my lifters now? Can I clean them out? Or will they not have any metal in them?
Old Jan 24, 2004 | 07:58 AM
Red95Formula's Avatar
I am not a expert engine builder but i would not reuse them. I would replace them so I wouldnt have to worry about it when I got it back together.
Old Jan 24, 2004 | 08:24 AM
Mike383LT1's Avatar
spun bearing
to sum it in one word no! For as enexspensive as a new set of comp 875-16's are i would swap a set in
Old Jan 24, 2004 | 08:52 AM
If you thoroughly/adequately cleaned them (you may have to take them apart), I don't see why they would not be ok to re-use.
Old Jan 24, 2004 | 09:46 AM
96ltz's Avatar
As long as you thoroughly inspect the rollers and bodies and can pull them apart / reassemble them for cleaning as mentioned without marking them up them should be OK.
Old Jan 24, 2004 | 10:48 AM
NOMAD's Avatar
If you can get them apart and cleaned perfectly, then yes. If not, no...
You are going to have the engine tanked and redone with new cam bearings correct ?
-Shannon
Old Jan 24, 2004 | 01:35 PM
v7guy's Avatar
so basically pop out the retaining clip and pull out the plunger and spring and wash them out thoroughly and then reassemble and I should be good?
Old Jan 24, 2004 | 01:39 PM
Right. As long as you can remove all foreign matter, you should be ok. Be sure to get them reassembled properly and make real sure the retaining clip is properly in the groove.
Old Jan 24, 2004 | 01:55 PM
v7guy's Avatar
alright, thanks a lot, I have unfortunately disassembled a few in the past, so other than some frustration I should be good to go
oldschool
Feb 9, 2016 09:21 PM
jayblev95
Dec 1, 2014 06:55 AM
1996LT1Z28
Dec 1, 2014 01:01 AM
1LEThumper
Jul 14, 2003 12:45 PM
