removing plug #6 with Hooker LTs?
Old Mar 26, 2006 | 09:35 PM
30th TA 0219's Avatar
OK, I'm getting frustrated, how the hell does #6 get removed with Hooker LTs?
#8 was pain enough (from underneath with a wrench on the end of the spark plug socket)
What's the secret for #6?
Old Mar 26, 2006 | 09:53 PM
LJ93Z28GM's Avatar
Re: removing plug #6 with Hooker LTs?
If you are using a spark plug socket with the rubber insert take take the rubber out and it will likey fit on there now.
Or get a offset 5/8 inch wrench or a regular wrench and get it directly at the base of the spark plug and try to keep the swearing to a minimum.
Also depends on how you put your dipstick try to move that around as well.
Old Mar 26, 2006 | 10:04 PM
F(ast)-body's Avatar
I always take the starter off to get to #6 and #8 from underneath...no problemo...
Old Mar 26, 2006 | 11:15 PM
it's really more of a header tube in the way issue
Old Mar 27, 2006 | 07:10 AM
cehan's Avatar
I always get at #6 & #8 from the bottom. I leave the starter in and I have a spark plug socket that I cut down to 2" with my die grinder. I use a ratcheting box end wrench on the hex head of the socket and I'm just able to get enough rotation to break them free (and torque them back down). The hardest part is to get the boots off after they've been stuck on there for awhile. I just changed all my plugs a few weeks ago, it took me 1 hr and 35 minutes.
Old Mar 27, 2006 | 08:17 AM
LJ93Z28GM's Avatar
I have the hookers and a socket that is cut down as well. I say about 45 minutes top, but my engine bay is far from stock.
Old Mar 27, 2006 | 08:43 AM
SentimentalValue's Avatar
This will probably end up being the easiest way.
Old Mar 27, 2006 | 08:46 AM
jsetzer's Avatar
I have hooker lts and use an open ended wrench on a spark plug socket. I can get all of them in/out, althout a few are a pain. I keep meaning to get one of those cut down ones, but never have.
Old Mar 27, 2006 | 09:49 AM
just bought a socket from Advanced Auto (no sense in cutting upa good one right?)
And now I have another excuse to cut some $hit up with power tools, right? lol
Old Mar 27, 2006 | 10:06 AM
wrd1972's Avatar
I have RK-sport headers and I have determined it would be easier to just remove the right side header to replace the plugs. #2 and #4 are very hard to reach due to the primaries. The other two I can get with the starter off also.
Old Mar 27, 2006 | 10:27 AM
dreamer1q's Avatar
Exactly what I do. Mucho easier. Can be done from the top, but I'm not that much of a bad dude
Old Mar 27, 2006 | 12:38 PM
well, the socket I bought and cut off wouldn't work, hole in it not big enough to go down on the spark plug, so I wound up cutting up my Craftsman anyway! Oh well, 10 minutes, off/on though!
jasonduaine
Apr 1, 2015 08:09 PM
donot_4get
Sep 14, 2002 08:03 AM
atljar
Sep 10, 2002 07:01 PM
96 TA
Sep 1, 2002 02:48 PM
GA93FORMULA
Jul 24, 2002 11:38 PM
