Removing an LT1/trans from the bottom
Old Jan 9, 2009 | 04:49 PM
Ekof96Z28's Avatar
Hey guys. I'm planning on starting this weekend on removing my old drivetrain.
Is there a writeup out there on how this is done? I searched and every URL I came up with was bad.
If not I guess I can fudge it but I figured it would be much easier if I didn't have to guess.
Thanks guys.
Old Jan 9, 2009 | 05:05 PM
Cam Can's Avatar
Here's one write-up.
http://www.michiganspeed.com/enginepull/index.html
Disclaimer: I've never done it.
Old Jan 9, 2009 | 09:22 PM
Ekof96Z28's Avatar
Thansk That will be helpful.
I liked the jackstands idea.
I was hoping for a shoebox style writeup but I'll take what I can get.
Old Jan 9, 2009 | 10:04 PM
Ekof96Z28's Avatar
Anyone else know of a webiste or have insight to offer me?
Thanks guys!
Old Jan 10, 2009 | 12:00 AM
ACE1252's Avatar
This write up was made by another member here and was extremely helpful in getting me prepared for the pull.
http://www.ace1252.com/LT1_Removal_F...ne_Removal.doc
http://www.ace1252.com/LT1_Removal_F...l_Pictures.doc
Here is another thread for discussion....
https://www.camaroz28.com/forums/sho...d.php?t=647893
Old Jan 10, 2009 | 12:39 AM
I didn't know I had a style.
I've done it, but did not make a write-up. I lowered mine out with a floor jack and left the wheels/tires on. Put a floor jack under the trans and wheeled it out. No fabrication of anything extra was done.
That's what I did on New Year's Eve one year.
Old Jan 10, 2009 | 02:13 AM
Ekof96Z28's Avatar
Sounds like a pretty good new years eve.
Ace those links didnt work.
Old Jan 10, 2009 | 08:12 AM
Cam Can's Avatar
Try this:
http://www.ace1252.com/LT1_Removal_From_Bottom/
Old Jan 10, 2009 | 08:48 AM
Ekof96Z28's Avatar
Thanks guys.
I'm releived to see that people have done it with low garage ceilings. Mine can't be more than 7-8 feet and I was worried about lifting it high enough.
Old Jan 10, 2009 | 10:35 AM
This one's pretty good.... don't know if it has enough "style" though
http://www.cardomain.com/ride/348183/6
Old Jan 10, 2009 | 04:10 PM
Not everyone has it, Fred.
Old Jan 11, 2009 | 10:32 AM
Ekof96Z28's Avatar
Okay guys. I was doing some reading and saw a picture of it being done without raising the rear wheels. I am running duals dumped at the axle. If I remove the exhaust beforehand will we be able to do it without putting the rear on tires and just chocking the rear wheels?
Also would you guys recommend the cherry picker? Or using a chain pull attached to rafters.
My buddies seem pretty adament about the chain pull idea, and I am all for using the cherry picker.
Old Jan 11, 2009 | 11:31 AM
Mystery Bird's Avatar
I've done it a few times and prefer the chain fall method because it frees up floor space and just feels safer to me. I put jack stands underneath when raising for extra safety, never trust one method alone. Also, remove your oil pressure sensor before or you will most likely will break it off learned that the hard way. First time I did it I went in blind and did it my self in about four hours.
KYWes
Jun 14, 2022 06:52 AM
Victor Lamb
Aug 26, 2017 02:52 PM
Fastbird93
Jul 11, 2015 04:37 PM
Jun 6, 2015 08:27 AM
sscott
Jan 17, 2015 04:30 PM
