Removing Fuel Rail....
Old May 20, 2008 | 01:36 PM
Jazsun's Avatar
All 4 bolts are out, whats the best way to pull it out without breaking it?
I pulled pretty hard but I am afraid I will break something. Is grabbing by the rails on both sides and yanking up the best way?
Old May 20, 2008 | 03:52 PM
rusnrno's Avatar
I lift one side at a time. If it's been a while since it's been off it might take a little extra force but it's pretty easy.
Old May 20, 2008 | 03:59 PM
ShownomercyZ28's Avatar
Yea you just need to wiggle it back and forth a bit to loosen up the injector O rings.
Old May 20, 2008 | 05:23 PM
Make sure the area around the injectors is clean, so no dirt goes in the engine when they come out.
Old May 20, 2008 | 06:20 PM
Z28James's Avatar
What I did was pop off the harnesses on the injectors and rock the fuel rails back and forth while pulling upwards. It took me a while but they will pop out.
Old May 20, 2008 | 06:24 PM
caldercay's Avatar
And use cone-shape rubber plugs (hardware store) to seal off the
injector holes so nothing falls in.
DirtyDaveW
Dec 1, 2016 05:37 PM
REDNECKISBOSS
Mar 22, 2015 08:31 AM
ANDYZ28
Dec 29, 2014 09:13 PM
Jul 4, 2005 05:00 PM
