removing fuel pump questions
Old Jul 25, 2005 | 02:18 PM
chevy1963's Avatar
Ok, I can't get the electrical connector to come off the fuel pump assembly. ( the yellow on on top where to fuel lines come out) How does that come off?
Old Jul 25, 2005 | 03:23 PM
chevy1963's Avatar
Re: removing fuel pump questions
also Do i Have to put the walboro back in the plastic container the stocker came in?
Old Jul 25, 2005 | 04:49 PM
Read the Racetronix instruction regarding reuse of the plastic housing (bucket). They consider it essential for proper fuel tank operation.
Frequently, "yellow" connectors will have a "safety" pin pushed through them.
Old Aug 3, 2005 | 09:00 AM
chevy1963's Avatar
Not the bucket for the pump. I talking about on top of the assembly that outside the tank where the fuel line come out of the take. There 3 wires that run from the wiring harness and connects the assembly, theres a yellow connector there that connects power to the pump. How do you get that off?
Old Aug 3, 2005 | 09:11 AM
Dude.... you asked "Do i Have to put the walboro back in the plastic container the stocker came in?" That's why I told you to read the Racetronix instructions regarding the bucket.
What am I missing here?
And I tried to answer that question as well. Did you check for the safety pin that is often used on yellow connectors?
I'm not sure if that's the problem, but it seems like I'm the only person trying to help.
"What we have here is a failure to communicate."
Old Aug 3, 2005 | 09:23 AM
chevy1963's Avatar
I checked as you said, the yellow connector has no pin no nothing holding it in. Sorry about the miss understanding.
Old Aug 3, 2005 | 09:28 AM
Racetronix's Avatar
E-mail support@racetronix.com for a copy of the instructions!!!
Old Aug 3, 2005 | 10:00 AM
chevy1963's Avatar
Thanks!
BADAZZ_Z
Parts Wanted
Mar 5, 2019 12:55 AM
Jessie4tin
Jan 7, 2015 08:53 AM
ANDYZ28
Dec 29, 2014 09:13 PM
blac94Z
Nov 24, 2014 07:12 PM
