Removing EVAP canister and solenoid?
Old Mar 27, 2006 | 04:39 PM
All_Z_Way's Avatar
Is it possible to remove the evap canister and the EVAP solenoid? This is on a race car where emissions are not important.
Old Mar 27, 2006 | 05:51 PM
Re: Removing EVAP canister and solenoid?
You can remove anything. You'll get a code for the missing EVAP solenoid, and for the vacuum detector switch. Cap the vacuum nipple on the side of the throttle body. Remove everything back to and including the charcoal canister. Leave the vent line from the tank/pressure relief valve and put a cloth filter over it so dirt won't get sucked back in as the fuel cools down and the pressure drops. I'd program out the codes and program out the EVAP flow, since it can try and operate the system at WOT.
Old Mar 27, 2006 | 07:11 PM
matLT1's Avatar
I did this over the winter just as described above. A issue I was concerned about though (because my car is still in storage and I havn't had a chance to drive it yet) is rather or not when you fill the tank, can gas potentially come out the vent line that I placed the filter over? What is it that keeps fuel from making its way from in the tank to out of that hose?
Old Mar 27, 2006 | 08:44 PM
All_Z_Way's Avatar
I am not really worried about SES lights....eventually I will have all after market gauges anyway.
Thanks for the help.
James
Old Apr 2, 2006 | 08:03 PM
blown383's Avatar
I just disconnected all of the hard plastic tubing from underneath the car because Im upgrading the fuel lines, now what do I do with the vent tube from the EVAP cansiter? Cap it off or?
-B
Old Apr 3, 2006 | 08:21 AM
You need a vent from the fuel tank. The stock cap is "unvented". By leaving the vent line from the tank, through the pressure relief valve, to the rear fender liner, and simply putting a filter of some sort on the end of the hose, you have "vented" the tank.
If you keep the canister, and want to know what to do with the nipple that the line to the EVAP solenoid was attached to, that nipple becomes an additional tank vent, and I would just put a cloth sock over it so nothing can get into it, pr cap it off.
Can fuel come out of the vent..... sure... if you completely overfill then tank to the point where its up to the top of the tank. But most race applications you wouldn't put more than 5 gallons in the tank.
Old Apr 3, 2006 | 10:33 AM
blown383's Avatar
Thanks Fred! I'm a little confused.. is there a diagram? I disconnected the line that is in the fuel line bundle thats underneath the driver's side door and that line goes to the back of the car. Im wondering what do I with it. Hopefully that clairifies things.
-B
Old Apr 11, 2006 | 05:29 PM
blown383's Avatar
ttt for fred to see!
-B
KYWes
Jun 14, 2022 06:52 AM
ducttape1975
Classic Engine Tech
Mar 26, 2016 04:17 PM
Boss002
Jan 20, 2016 12:17 PM
ducttape1975
Jul 10, 2015 06:29 PM
