removing the cat!
Old Jul 15, 2012 | 03:39 AM
javi805's Avatar
removing the cat!
Ok we all know how cali if strict with the emisions! Well I was thinking of removing my cats after my smog in sep. I wont have to do it again till 2014. What do yall think, would be a benefit to remove the cat converters and put em back on before I smog it again?
Old Jul 15, 2012 | 07:52 AM
Re: removing the cat!
Probably a couple HP at best. Definitely not worth the effort.
What happens if a cop is sitting behind you in traffic and smells the unburned fuel?
Old Jul 15, 2012 | 10:43 AM
Bud M's Avatar
Leave them on, they are there for a reason.
Old Jul 15, 2012 | 11:59 AM
javi805's Avatar
I wil def take that into consideration thank you
Old Jul 16, 2012 | 07:46 AM
Ocala93TA's Avatar
move outof cali is my suggestion then remove cats
Old Jul 16, 2012 | 11:01 AM
Erik Castaneda's Avatar
i would but the when cops find out you dont have they will take away your car dude
Old Jul 16, 2012 | 11:28 AM
Ocala93TA's Avatar
Another suggestion get a extra set gut them out make both sets so you can easily bolt and unbolt . Pass emissions unbolt original set put on gutted then flip back before emission testing again , but I believe you would need to tune your back o2 out because you have 2 after the cats I think ? Or it will throw a ses light
Old Jul 17, 2012 | 12:37 PM
2QUIK6's Avatar
I just had to do this, bolt back in the cats for emissions. But mine aren't removed for performance, really not much gained if you have hi flow cats. I remove them because the lt headers sit so low my wife doesn't pay attention to bumps and driveway ramps and speed bumps and ends up bottoming out and scrapping them and breaks the substrate in them. After buying several replacement I simply hollowed them out so it appears I have cats. 3-bolt flange to the header and a slip fit band clamp on other end, takes about 15-20 mins to remove and replace with real cats with same fittings.
Yes on a 97 you'll need to program out the rear o2s or replace with sims. But again not much performance gain for the time if you have hi flows already.
Old Jul 17, 2012 | 02:31 PM
Loonies's Avatar
As others have said....its not worth it. Spend your time and money on a real mod
R@mpage
Apr 20, 2015 10:02 AM
lt1matt
Mar 21, 2015 07:35 PM
alex5366
Mar 8, 2015 11:32 AM
Iamherefornow
Jan 26, 2015 04:57 PM
alphaauto
Jan 23, 2015 07:42 AM
