Removing The Cat?
Old Oct 6, 2003 | 09:09 AM
djn's Avatar
djn
Removing The Cat?
I have a 1995 Z and want to have the Cat removed. Is there an 02 sensor to worry about or can the Cat just be pulled off witout affecting the computer?
Any help would be appreciated.
Old Oct 6, 2003 | 10:07 AM
Like My Taillights?'s Avatar
It will be tough to pull off considering its welded to the y pipe
You can unbolt one side and cut it off and weld a pipe in its place,or remove the y pipe, gut it out and bolt it back up. OR, buy some headers , gut the cat, have a flange welded on to the cat, that way its removable. you could swap in an offroad pipe. as for the O2's you'll be fine, they are before the cat, so no codes.
R@mpage
Apr 20, 2015 10:02 AM
lt1matt
Mar 21, 2015 07:35 PM
alex5366
Mar 8, 2015 11:32 AM
Iamherefornow
Jan 26, 2015 04:57 PM
alphaauto
Jan 23, 2015 07:42 AM
