Removing the battery tray/coolant overflow container
Old Mar 24, 2004 | 02:35 PM
GREGG 97Z's Avatar
I just finished relocating my battery to the trunk and was looking at removing the ugly battery tray/coolant overflow container. I got it out easy but for those who removed it what did you put in it's place? I thought about just sticking some sort of small container down in the hole left there and securing it with some zip ties, just looking for some good ideas and what's required for it to pass a tech inspection.
Old Mar 24, 2004 | 02:53 PM
rmackintosh's Avatar
Go to Home Depot, get a nice flat plate of aluminum, cut it a little over the size of the opening, and pop rivet it in!
Will look cool!
Old Mar 24, 2004 | 03:02 PM
GREGG 97Z's Avatar
Will look cool!
That sounds like a good idea for covering up the hole left but what about a container for the coolant overflow? Is there a certain size or type of container required to pass an NHRA track inspection or can I just use any sort of plastic container?
Old Mar 24, 2004 | 03:09 PM
You have to have a "catch can" to pass tech, and as a courtesy to other racers.
JEG's and Summit sell lightweight plastic and aluminum catch cans. If you are locating it below the radiator overflow level (most likely), you will need one with an internal tube, or a bottom connection that allows the radiator to pull coolant back into the radiator as it cools off. Or else you will need to top off the radiator after each use - not a good idea with the LT1.
Old Mar 24, 2004 | 03:20 PM
GREGG 97Z's Avatar
That's right, I forgot what they were called. I just checked them out at Summit, they range from around $50-$100, I'll go with one of those. Thanks Fred.
Old Mar 24, 2004 | 03:28 PM
All you need is one of the JAZ plastic ones... $19 at JEG's. I have one, but haven't installed it yet.
Old Mar 24, 2004 | 03:37 PM
GREGG 97Z's Avatar
I just checked them out, they are 4"x10 3/4" that sounds like it would fit in that hole, I'll have to check tonight. I really didnt care about a real nice aluminum one since I want to hide it in the hole anyway and $19 sounds much more like it to me.
Old Jan 25, 2006 | 06:56 PM
c0rey's Avatar
Re: Removing the battery tray/coolant overflow container
I cant find the jaz one you mention injuneer you have a part number for me?
Old Jan 25, 2006 | 08:10 PM
97formula808's Avatar
how much coolant should the new catch can be able to hold? i was going to buy one of those cheapies from ebay to replace but i dont know if they hold enough.
DirtyDaveW
Dec 1, 2016 05:37 PM
DSMKilla
Jun 11, 2015 05:02 PM
eanhl2004
Apr 4, 2015 12:01 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
ddr698
Dec 31, 2014 09:16 AM
