reluctor ring/gear install question
Old May 30, 2003 | 12:26 PM
LWillmann's Avatar
I have a 96 Formula with 2.73 gears. The car has ABS and TCS, so I assume it has 4 channel ABS.
I purchased a used 3.42 ring and pinion gear set (low mileage)
I also purchased a 3 series differential.
I know I need a gear install kit, but do I also need to track down a reluctor ring?
I would think if the car has 4 channel ABS, that the rear wheen speed sensors are at/near the wheels, so that would negate the need for the reluctor ring..But I'm not sure.
Can anyone shed any light on this for me?
Old May 30, 2003 | 12:57 PM
IDOXLR8's Avatar
If your current gear is a 2.73 then you should have a series 2 carrier in your rearend. In this case since you are upgrading to a series 3 carrier you will need a new reluctor gear designed for a series 3 carrier.
Old May 30, 2003 | 01:06 PM
LWillmann's Avatar
What exactly is the reculctor ring for/what does it do?
Old May 30, 2003 | 01:17 PM
Don 97 SS's Avatar
It is part of your antilock brake system. No reluctor ring: no ABS worky.
Old May 30, 2003 | 02:05 PM
LWillmann's Avatar
Someone told me that because my car has traction control (TCS), it has 4 channel ABS and doesn't need the reluctor ring.
If they're wong, it's cool, I can order one before I do the install.
Old May 30, 2003 | 03:06 PM
Yes.... TCS is 4-channel, and 4-channel has a small reluctor ring on the end of each axle, and a sensor on the hub. Non-TCS is 3-channel, and 3-channel has only a single reluctor wheel on the rear axle, mounted on the differential carrier.
Old May 30, 2003 | 03:16 PM
LWillmann's Avatar
So if mine is 4-channel and has small reluctor rings on the end of each axle, do I need to purchase none, or two, reluctor rings?
SLP only shows one reluctor ring part number on their site.
Injuneer, you make it sound as though I don't need to replace it/them because they're on the axle and not the carrier.
Old May 30, 2003 | 10:04 PM
LWillmann's Avatar
ttt...
Old May 30, 2003 | 11:01 PM
No reluctor on the carrier is shown in the parts book for the TCS equipped car. The reluctor looks like it is part of the axle. I don't even see a separate part number for one.
Old May 30, 2003 | 11:18 PM
LWillmann's Avatar
Sweet, thanks!
No reluctor means $20 toward some other mod!
HectorM52
Jul 30, 2017 11:46 AM
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
nautilus
Aug 22, 2002 11:49 PM
Chrisdude
Jul 24, 2002 02:25 PM
