Relocating oil pressure sender>>???
Old May 25, 2006 | 07:08 PM
mattbailey's Avatar
On my stock motor, the oil pressure sender is above the oil filter. On my new motor I would like to move it to the back of the intake. Anyone done this? What is required? Thanks.
Old May 25, 2006 | 09:39 PM
1racerdude's Avatar
Re: Relocating oil pressure sender>>???
Fittings are required and it shouldn't hurt a thing. If ya got LT's it will get it out of the heat.
Old May 26, 2006 | 12:43 AM
redemn93's Avatar
most lt1s have the sensor on the back of the intake from factory no? unless different years changed. either way though you'll be fine. like 1 racerdude said, youll need fitting. no biggie.
Old May 26, 2006 | 06:49 AM
93s and early 94s have them on the side of the block above the oil filter.
Old May 26, 2006 | 07:04 AM
Javier97Z28's Avatar
Moderator
Your old 93 had the sensor where we just put the autometer mechanical gauge sensor on mine Wednesday...
Old May 26, 2006 | 10:13 AM
Gripenfelter's Avatar
All you need is a plug to screw into the old location. You can actually remove the plug from behind the intake and screw it into the hole above the filter and screw the sensor into the new location.
Nothing else needed.
Old May 26, 2006 | 10:23 PM
OBE1 95Z28's Avatar
Here's a photo from Shoebox's site of the fitting to relocate the sensor:
http://shbox.com/1/op_sensor.jpg
Fittings are: GM P/N 10137636 $6.04
Old May 27, 2006 | 07:31 AM
mattbailey's Avatar
Thanks fellas. I'll be moving it on my new motor because the sensors so close to my exhaust. Makes it a real PITA.
HectorM52
Jul 30, 2017 11:46 AM
surreybrad
Apr 22, 2015 06:40 AM
KYWes
Apr 15, 2015 05:48 AM
ad356
Apr 11, 2015 08:49 AM
transam_388
Mar 15, 2015 11:53 AM
