Relocating oil pressure sender>>???
On my stock motor, the oil pressure sender is above the oil filter. On my new motor I would like to move it to the back of the intake. Anyone done this? What is required? Thanks.
Re: Relocating oil pressure sender>>???
most lt1s have the sensor on the back of the intake from factory no? unless different years changed. either way though you'll be fine. like 1 racerdude said, youll need fitting. no biggie.
All you need is a plug to screw into the old location. You can actually remove the plug from behind the intake and screw it into the hole above the filter and screw the sensor into the new location.
Nothing else needed.
Here's a photo from Shoebox's site of the fitting to relocate the sensor:
http://shbox.com/1/op_sensor.jpg
Fittings are: GM P/N 10137636 $6.04
surreybrad
Apr 22, 2015 06:40 AM
