refresh my memory, changing plugs
Old Aug 29, 2009 | 10:56 AM
SinisterFormula's Avatar
yeah i'm sure that my plugs are original (75k miles) and i think that they are way tired.
i did the 7 easy ones on my friends 95z like 3 years ago, and when we didnt have the tools to get the illusive 8th one out, he brought it to the mechanic. i dont feel like paying 3 times what the plugs cost to have a guy do one for me.
what tools do i need or does anyone have a tech page that shows you how to get to that one? that and since i wanna replace some little things before the season winds down, what should i do besides wires/plugs/fuel filter? the car hasnt cost me anything since i've owned it so i dont mind dropping a few hundred and a handful of hours doing it.
Old Aug 29, 2009 | 11:02 AM
Z28Nut's Avatar
It's been a while since I changed plugs with the stock manifolds - which I'm assuming you have - but I remember it was easier to get to some of the plugs from underneath the car and it was worth pulling the alternator to get the #2 plug (front pass. side). A spark plug socket, open end wrench to fit on that, a 3/8ths ratchet for the ones you can use it on and a spark plug boot puller is nice. Have fun! I don't miss my stock manifolds.
Old Aug 29, 2009 | 12:50 PM
bw_hunter's Avatar
Seven easy one hard is sort of optimistic...chuckle.
The ones on the drivers side are relatively easy. The passenger side is pretty not easy. If you drop the y-pipe you can get the back two fairly easily,from underneath, removing the alternator helps get the front two from the top. The air pump cross over pipe makes it a little tougher than it has to be...
All in all, expect to spend a few hours doing it. Long tube headers make it much easier....believe it or not!
Old Aug 29, 2009 | 04:03 PM
rclearyiii's Avatar
#8 Plug Change
I just changed the plugs on my 96 m6 a couple weeks back. I removed the starter and used a closed end 5/8th wrench with a slight offset and had it out and in after about 10 minutes of starter removal.
Old Aug 29, 2009 | 05:42 PM
thank you for that. i just did my starter and didnt even think of that approach. like i said i havent had any problems with this car (knock on wood) in the 10k miles i've had it. so i havent been under it too many times.
PCLZ28
Dec 24, 2015 05:19 PM
captcorvette
Mar 7, 2015 12:37 PM
grgguy
17
Feb 23, 2015 07:57 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
