Red arrow dash light flashing
Old Aug 9, 2009 | 06:06 PM
rsjay's Avatar
My red arrow on my dash keeps coming on. I checked my coolant fluid and it is not low. Does it mean my coolant sensor maybe gone?
Old Aug 9, 2009 | 06:15 PM
bw_hunter's Avatar
What red arrow?????
Old Aug 9, 2009 | 06:36 PM
n2ceptor's Avatar
Originally Posted by bw_hunter
What red arrow?????
And what kind of vehicle??????
Old Aug 9, 2009 | 08:31 PM
rsjay's Avatar
1994 LT1 Camaro. Red arrow that comes on the dash lights which usually means low coolant.
Old Aug 9, 2009 | 08:34 PM
brianswimmer23's Avatar
yea it sounds like it needs to be cleaned, or ,ight not be plugged in all the way check the connection.
Old Aug 9, 2009 | 09:24 PM
That Camaro Guy's Avatar
The sensor is located on the passenger side of the radiator, in the upper middle area, facing the back side of the car. These sensors are known to act up for no reason on occasion. You can replace it, or unplug it. There will be no check engine light or engine codes if you disconnect it.
Old Aug 9, 2009 | 09:40 PM
Where did you check you "coolant fluid" level - in the radiator or in the reservoir?
Old Aug 10, 2009 | 06:04 AM
rsjay's Avatar
I checked the fluid in the radiator and appeared to be full.
Old Aug 10, 2009 | 08:42 AM
click
Old Aug 10, 2009 | 09:18 AM
rsjay's Avatar
Thanks.
warmeck
Feb 5, 2015 11:04 AM
dirtybird81
10
Jan 6, 2015 09:31 PM
Collector Car
Dec 17, 2014 01:12 PM
fpete1992
Dec 11, 2014 03:51 PM
Jul 4, 2005 05:00 PM
