Red arrow dash light flashing
My red arrow on my dash keeps coming on. I checked my coolant fluid and it is not low. Does it mean my coolant sensor maybe gone?
Originally Posted by rsjay
(Post 6068388)
Originally Posted by bw_hunter
(Post 6068399)
What red arrow?????
1994 LT1 Camaro. Red arrow that comes on the dash lights which usually means low coolant.
yea it sounds like it needs to be cleaned, or ,ight not be plugged in all the way check the connection.
The sensor is located on the passenger side of the radiator, in the upper middle area, facing the back side of the car. These sensors are known to act up for no reason on occasion. You can replace it, or unplug it. There will be no check engine light or engine codes if you disconnect it.
Where did you check you "coolant fluid" level - in the radiator or in the reservoir?
I checked the fluid in the radiator and appeared to be full.
Thanks.
