Rear main seal - Exact size? Ty!
Old Apr 4, 2009 | 06:01 AM
flexus's Avatar
Hey!
I'm in need of a Rear Main Seal fast, and I have no time to order one from across the ocean. I'll try to have a go at a universal one but the internet refuses to show me any size.
Could anyone please, if they know, tell me the exact size of the '96 LT1 Rear Main Seal? (inside diameter, outside diameter, thickness)
Thanks!
Old Apr 4, 2009 | 09:17 PM
flexus's Avatar
Up! Someone's gotta have one lying around and can measure it
I'll give you a cookie!
Old Apr 4, 2009 | 09:37 PM
bombebomb's Avatar
Why not just go to an auto parts store? Even a dealership if this is an emergency (otherwise don't cause they will charge a arm and a leg).
Old Apr 5, 2009 | 02:44 AM
flexus's Avatar
I live in Romania, eastern Europe. There are NO dealerships or authorized services for US Chevys... Ordering it would take 10 days and I have 5 until the clutch comes and 7 until a race event And spending 60$+ to get it fast enough just doesn't sound right...
Old Apr 5, 2009 | 03:27 AM
bombebomb's Avatar
I stand corrected.
Old Apr 5, 2009 | 09:11 AM
96capricemgr's Avatar
You know that that seal is the same as all the other smallblock Chevy's going back to 1987? Not sure if that helps you atall, does give you a bigger list to search though.
Old Apr 5, 2009 | 01:31 PM
97 6SPEED Z's Avatar
Thumbs up
All measurements are in inches and were taken with a 6" dial caliper (supposely accurate to +/- .001"), on a used LT1 rear main seal and crankshaft sitting in my garage which were replaced/pulled after approximately 86,000 miles of service.
Rear Main Seal Dimensions: O.D. = 4.532" I.D. = 3.720" Thickness = .490"
Crankshaft Sealing Surface: O.D. = 3.742" (Measured where the seal I.D. rides, i.e. looks like there is still a .022" interference fit on this used seal).
Hope this info helps?
Old Apr 5, 2009 | 01:53 PM
One of the fields in your "Profile" is "Location". Why don't you enter your "Romania" or "Eastern Europe" location, so it shows up under your screen name, on the left side of the post. That would help avoid questions like the above.
Old Apr 5, 2009 | 03:16 PM
flexus's Avatar
Yep that's about what I needed to know, thank you "97 6SPEED Z" !
Converted your measurements to "milimeters - mm" and going to ask for a 115mm od - 95mm id - 12.5mm thick seal. I'll prepare a big enough hammer to fit it
Making the changes now Injuneer
P.S. It has also crossed my mind there used to be a Cadillac/Corvette/Hummer dealer who stocked GM parts but last time I went by they moved/closed the place. Might try giving him a call tho...
Old Apr 5, 2009 | 04:15 PM
mdacton's Avatar
do you have any regular auto parts places? Can you get an aftermarket one?
I can mail you one if you need, not sure how much shipping would be
Old Apr 5, 2009 | 04:55 PM
flexus's Avatar
We do have lots of "universal" parts places with huge stocks but they're mostly for european stuff. One of them said they have all sizes of seals and I should give them the size to find me one.
Thanks for the offer to help mdacton. I'm not sure if there is something that will arrive in 4-5 days and won't cost too much to be worth it. I tried to order one since thursday/friday but the guy from the shop I contacted forgot/didn't care enough to do it in time. USPS regular mail is 12$ and takes 6+days.
This seal isn't worth the trouble I'd be putting you through to find a shipping provider, send you money, get it from store, mail it etc etc. Thanks a lot for offering though
Old Apr 5, 2009 | 08:31 PM
mdacton's Avatar
what brands do they sell?
maybe if you can find a part number for an american one, like national seal or something you can cross refrence it
Old Apr 6, 2009 | 12:53 AM
flexus's Avatar
From their site (http://www.alpadrino.ro/simering_mix.htm) it seems they have these brands:
Musashi; MAP; NOK; Victor Renz.
None of them have detailed product# listings
Old Apr 6, 2009 | 05:06 AM
flexus's Avatar
Well this is embarrassing but guess what I found between some magazines on a shelf in my room?
Yep, the Rear Main Seal from an old gasket set I had I had the gasket but the seal was missing and I figured it was lost or something...
Old Apr 6, 2009 | 07:01 AM
LOL, turned out to be a worthwhile bookmark.
HectorM52
Jul 30, 2017 11:46 AM
barry76lt
Events and Cruise Spots
13
Jul 21, 2015 06:17 AM
Chet1185
Feb 4, 2015 09:51 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
squarehead
Nov 21, 2014 08:02 PM
