Rear main making some noise
Old Oct 14, 2005 | 10:40 AM
MY91Y84's Avatar
my 190,000 mile LT1 in my caprice is making some noise...im almost 100% its the rear main bearing...how do i quiet it down?
Old Oct 14, 2005 | 10:51 AM
OBE1 95Z28's Avatar
Re: Rear main making some noise
If it truely is the rear main bearing, you'll need a rebuild or partial rebuild to fix it. At a minimum the crank would need to be removed, turned and new bearings installed. Seeing that you're at 190K miles, I suggest a full rebuild.
Old Oct 14, 2005 | 12:04 PM
MY91Y84's Avatar
well, my current situation wont allow me to do that..i know how to fix it but i dont have the means to do that right nowl..im in NYC and i dont have a driveway or even the same parking spot everyday....so pulling the motor on the street would be a big no no...not only that but this is my transportation....and im religiously against taking MTA, so this motor HAS to make a little longer....i havbe my carbed LT4 from my Trans Am that im trying to sell, so as of right now putting that motor in is out, although id like to, im seriously short on funds right now...so what im looking for is something to quiet it down to make it last to 200,000 then i should be in a situation were i could replace it
Old Oct 27, 2005 | 07:59 AM
MY91Y84's Avatar
heres a little update....i added some lucas oil stabilizer and the noise went away...my oil pressure is stable and theres no knocking on cold startup...
LUCAS=
HectorM52
Jul 30, 2017 11:46 AM
jcamaro95lt1
Jan 24, 2015 08:21 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
siguy
Nov 27, 2014 10:07 AM
squarehead
Nov 21, 2014 08:02 PM
