rear brakes dragging?
Old Dec 21, 2003 | 11:15 PM
Nomar's Avatar
I recently got my rear rotors turned and installed new pads. However, i forgot to grease the pads with that white grease they give you. Now when I accelerate and let off the gas, the car slows down real quick. It almost feels like Im riding my brakes gently. Is it possible the rear brakes are draging as a result of me forgetting to grease the pads?
Any other ideas?
Thanks,
Dave
Old Dec 21, 2003 | 11:19 PM
S.J.S.'s Avatar
Nah...highly doubt it. Run it for awhile and see if it goes away.
Old Dec 22, 2003 | 12:30 AM
Nomar's Avatar
Thanks for the reply....i was hoping that was the answer since that would be an easy fix
TTT any more ideas?
Old Dec 22, 2003 | 01:13 AM
Heatmaker's Avatar
Advanced Member
Did you grease the "Brake Rods" or what ever they call those things. When you take your rear brake apart it's good to lube those rods up to keep them from sticking. I had dragging rears...and when I decided to spary everything...I just greased those rods up and they seemed to stop dragging. Dunno...
Old Dec 22, 2003 | 02:09 AM
S.J.S.'s Avatar
TTT any more ideas?
What do you mean.... take you 20 minutes tops.
Old Dec 22, 2003 | 07:25 AM
thermwood1's Avatar
Did you use a c-clamp to release the caliper pressure? If so, it might be a good idea to bleed all of the brakes, it is possible to get air in the lines and that can cause some funky problems. Just remember to start at the one furthest from the master cylinder and work your way forward. My .02
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Jlo
Apr 3, 2015 10:32 AM
Jazsun
Dec 29, 2014 12:14 PM
trefidy
Jul 26, 2002 03:40 PM
